Temp sensor plug wire
dugedug
Anyway to pull the plug apart to rewire the connector on the wire harness side? My ground has broken off at the connector so I get code #2. Thanks.
There is a part # for to replace the connector, but it is not a standard reorder part. I replaced my connector last year for the same reason.
I think someone on TY told me the part number, but I am not sure if I will be able to find it.
Found the link to the old Post, but it doesn't say a part number. I think I had to call a Dealer and explain to them that this was a special part order that Yamaha made this available because this has happened to several people.
http://www.totallyamaha.com/forums/showthread.php?t=2160&highlight=Thermo+Sensor
SX700RNY
i fixed mine once, there is a small metal tab that you have to push in, and pull the connector out. then i reconnected the wire to the connector and finished it off with some black silicone around where the wires go into the connector. it is a free fix but will take some monkeying around.
Just for refence if anyone needs the part number or searches for temp Sensor, it is 8EK-TSCON-KT, The description is Temp Sensor Connector Kit.
I found the yamaha bag that it came in in my sled while I was riding today.
85 miles of riding and only 10 miles to trailer the sleds.
