MM70001
Could you guys post examples of high mleage on redhead engines with the typef oil you used?
kallio
12k with anything from yammi lube to amsoil run in mine
7500miles amsoil since 3000miles
SWEDE
Over 13,000 miles on mine with Amsoil and Yamalube. I actually think I prefer the Yamalube over the Amsoil. It seems to burn a lot cleaner, but not sure which is better as far as wear protection. I did pistons and rings around 8,800 miles and everything looked good and clean, but ring end gap and skirt were out of spec.
TopGunnSrx
Probably 12k on Yamalube on a modded red, still had cross hatching when we parted it out. Im against amsoil because it smells like burning butthole lol
to funny..I used to use amsoil,but to expensive.Now running SHELL ADVANCE ULTRA..good stuff.And cheaper in price.TopGunnSrx said:it smells like burning butthole lol
sent you a pm also...about a name...
SRX500kid
this is going to turn in to another
on oil!!!!! lol!
on oil!!!!! lol!Devilin AblueDress!
My buddys 01 sxr 700 has 12,000+ miles on it. Freshened up @ 6k, complete rebuild @ 9k he has ben running the walmart brand since 9k. Says its as good or better than the amsoil he was running and its 10-12 bucks a GALLON!
Dnrtheil
2002 SX600R 19,008 miles, all stock, minus a couple of water pump seal kits. Yamalube for about the first 14,000 and now Citgo Sea and Snow.
http://www.totallyamaha.net/forums/showthread.php?t=86534
Derek
Derek
staggs65
cant comment on the oil, but a testament to the engine: I'm looking at a v-max deluxe right now with just under 25,000 miles.....$600. dont know why I havent pulled the trigger yet
