problem will be when you get too big the skirts get too thin and the cylinders will want to crack at the exh ports and the bottoms of cylinders wont have much strength. I have gone bigger then 780's(73mm) before to 74mm but it starts to get THIN!! Honestly if you wanted bigger youd need to make custom sleeves for engine or get aftermarket cylinders for that engine base.
