born&bread yamaha
I have a 1985 srv and I'm looking to reduce the slop in my steering. Help anyone?
YamaChris
They sell shim kits, I think Shadetree has one. If I remember right that is only a patch. The real fix was to press out bushings in the arms, maybe look at a Yamaha parts picture that some of the dealers that support the sight have. I can't remember if all the TSS had those or not. Maybe both would really tighten it up.
Press out the old bushings and buy the ones from a vmax4 they are bearing and new collars an seals an you will be good to go.
Yamaha Nutz
spi has a full collar and bushing kit that is the only fix the stupid shim kits do not fix the problem.............and unless you want to brake the bank the vmax 4 set will cost a arm and leg and last about as long as the std set up
