dsc577
I put on a 2 up seat and added a backrest from a older model,the grips will plug into the seat wiring without the rear switch,probably have to move that to the dash,where can i hook the seat wiring to?does it just need a positive and ground with no resistor?the switch is just on and off,i have a heated visor plug,would using those wires work.
thanks
thanks
sleddineinar
I have a manual with a wiring diagram if you need it.
dsc577
cool,im thinking of just hooking the grip wiring and switch into the tail light and ground wire
dsc577
took another look and it just plugs into the seat,works just fine,duh,feelin like winter and it gave me a chance to start her up anyway.not a bad day
sleddineinar
dsc577 said:took another look and it just plugs into the seat,works just fine,duh,feelin like winter and it gave me a chance to start her up anyway.not a bad day
Cool! I'm getting itchy to ride.
