rear grip wiring?
dsc577
coon rapids,mn
I put on a 2 up seat and added a backrest from a older model,the grips will plug into the seat wiring without the rear switch,probably have to move that to the dash,where can i hook the seat wiring to?does it just need a positive and ground with no resistor?the switch is just on and off,i have a heated visor plug,would using those wires work.
thanks
took another look and it just plugs into the seat,works just fine,duh,feelin like winter and it gave me a chance to start her up anyway.not a bad day
