02 Srx 144 Rebuild
Yup.... I would buy some GM engine de-greaser and soak them in it for like....a month!!!
There's part of your power problem!
Gotta keep em' clean and ya gotta keep em' adjusted. You're going to notice a big power increase once you get those power valves clean and adjusted. Plenty of reading on here about power valves.
FJ X 2
I think the adjustment is more of a factor on the pull throughs but letting them get real dirty is a large contributing factor also. It seems like people tend to tighten them up too much but that's just my opinion.
getting closer looks alot better than it did and the track is finally flat i droped the back end down in the drop down plate one hole ....opinions please
I'm running my track with about an inch hanging down from the bottom of the skid. Yours could need more/less though.
I use 1 inch also. I looked at the book and it says to use 22lbs of weight in the center of the flat part of the track then measure the distance from the bottom of the hyfax down to the top of the track. It should be between .98 to 1.18 inches.
put the new power valve in and this is what i have it full of slack and i have no idea what i am doing please help
rebuild almost complete new bender can, bender clutch kit, 144 camoplast cobra track 1.35, runs and drives great its a totally different sled just need to get some new skies thanks for all your help
I just got a set of Slydog 7" powder hounds in Urban camo. Awesome skis. Easiest ski I've ever installed. They also look the best. Check em out.
