700 sx clutch help
litchfield, MI
I would like some help with clutch setup. I have Aaen triple pipes 22/40 gears 1050 elevation. I would like to try and get it running more efficient. It hauls pretty good now but I know there's more in her. Plus I only got 7mpg in the up last season and it got almost 15mpg the year before with a rumble pack and stock gearing. Any help would be greatly appreciated. Thanks
you want better mpg.... remove the triple pipes and put the single back on lol.
those triples are flowing alot more. mileage is out the window now
I'm not really worried about mileage I just thought is she be a little better. As for clutching parts I have none I was hopeing to get some input so I know what to get
what do you have in it now ...flyweights ,springs ,helix..etc... that sled is very finicky with the air box mod... put it back to stock! also what jetting?
put a 52- 42 or close to it ,helix. put some 8-cr flyweights in it and adjust to shift out at around 9000 rpm. drop needles half clip pos. turn fuel screws out to 2 turns! That should get ya a lil better. just watch your plugs ! on warmer days ..pull the shelf outa the airbox!
use your stock springs and try 3.1 gms in side hole and 2. 4 grm in tip. if rpms too low put lighter rivet in tip
That sounds right in line for triple pipes vs stocker as far as milage goes.
1. Clutch it
2. Carbon Tech reeds & spacer/notch
3. Track and x-fer rods.
