SXvmax700
i have a vmax pogo setup and i want to lower it up front.
i know there is a kkit for the vmax 4 but the others?
ideas?
ideas?
i have achieved this 2 different ways. with both, there is no returning to original unless you have aquired extra parts.
simplest and cheapest is to remove the bump stop at the top of the spring, cut the tapered portion off and reinstall it. this will drop the front proportionately to what you cut off.
second option i have used and a bit more involved is to take the spring seat(the sleave where the bottom of the spring meets the top of the strut) and modify it by adding a length of tube to it. i cant remember if you will have to cut both ends off and section a piece of tube between, and weld back together or just add the tube section and weld. easy to determine, the seat needs to allow the spring to ride further down the strut, basically compressing the shock while still holding things in place. again, drop is proportionate to added material.
Call bender racing they made them for racing that's where I got mine
