Sxviper700 2003
Raysxviper
Maine
So I have sxviper 700 2003. I want to change things up "looks wise". Other then gas cap, Pull cord handle, windshields, and flaps what can i change under $200.00? Another thing can i change my rear light color? ANYTHING YOU THINK WOULD MAKE THE SLED DIFFERENT comment or post!!
Thanks guys
Shock covers, clear tailight lens, bar ends, paint your hood screens, running board trim,tunnel reinforcement braces, different colored idler wheels ( If you do this, swap for the Polaris wheels, they're bigger and will help with hyfax wear). There are a few companies that do the sled wraps.Probably some other things but that's all I can think of right now.
trailing arm caps, spindle caps, blue bar pad, handguards, bar riser, headlight covers, decals, colored hyfax, tunnel supports or rox treads if you can find a set, skidplate, polished tunnel, white gauge plate, c&a or other aftermarket skis (should be able to buy a used set around 200). I actually have a few of these items for sale if you decie you may want them (bar risers, blue bar cover, handlebar ends)
