rangermike14
Hey guys, I was told that my skid has Viper shocks. I am just curious... Can anyone tell me exactly what I have here? What parts are from the Viper? Is the whole skid from a the Viper or is there certain parts that are or what? I am just wondering what I have I guess. Check out the pics and let me know! I just took the skid apart and painted and had the w arm all beefed up with angle iron! The old w arm was shot! Thanks alot, Mike
photo storage
picture hosting
images
picture sharing
upload
photo storage
picture hosting
images
picture sharing
upload
gil7247
I think the center shock(front of skid) is on upside down all of mine are installed threads up on the center shock. Ohter then that and the adjuster (I think Bener) on the trafer rods it looks just like my 2 Vipers.
Skidooslayer687
gil7247 said:I think the center shock(front of skid) is on upside down all of mine are installed threads up on the center shock. Ohter then that and the adjuster (I think Bener) on the trafer rods it looks just like my 2 Vipers.
X2 mines installed the same way
motorhead327
Its sorta hard to know by pictures, you need to measure the shocks from center of each eye to eye!
staggs65
without measurements no picture will truely determine a srx skid from a viper.
gil7247
Isn't the only differences in the shocks and the 2 relay rods that run along side the rear shock?
rangermike14
The shock in the middle is the viper size. That's what I was told by a measurement. I don't have the measurement on me now. I just wondered if anything else was different. Is it going to matter that the shock is mounted upside down? Do I need to take the skid back out and change that or is it ok? It was like that when I got it so I just put it back together the same way. Thanks
motorhead327
Viper shocks are 18.5 rear and 13 " on the center one. And yes you want the ice and snow to fall away from the piston seal not into it!
rangermike14
OK. Thanks.
If I am not mistaken viper skids had a alum rod not steel on the middle mount point.
rangermike14
Are you talking about the shaft with the small wheels that the long shock mounts too?
rangermike14
Does that mean mine must be an SRX skid then?
No I sorry I meant rear mount point the rod in the tube not the steel of outside my bad
livewire_101proof
Most viper rails also had 2 different holes for the transfer rods also, depending on what length rods u had determined what hole u used. Short travel used one and vipers along with other long travel sleds used the other hole.
My 2000 srx only had one hole for the shorter rods. Not sure if 01 and 02 were the same or if they had rails like the vipers.
motorhead327
livewire_101proof said:Most viper rails also had 2 different holes for the transfer rods also, depending on what length rods u had determined what hole u used. Short travel used one and vipers along with other long travel sleds used the other hole.
I think the 98 srx had the long travel transfer rods though?
My '01 SRX had both transfer holes on the rails (I transfered the rails to the Viper skid I bought).
As far as I know, the only major differences are transfer rods, limiter straps and shock/spring length.
I would say by the picture you have either 02 updated version or 03 and up viper shocks. The rails look like the stock 98/99 style rails and they have the srx steel strap that connects the last idlers to the rear arm pivot. Transfer rods look like maximum performance.
The rods are correct length for long travel skids.
rangermike14
Cool. Thanks for the info guys!
rangermike14
Betheviper...I'm gonna attempt to set the suspension up like your set up threads once I get my ohlins extensions in. Wish me luck!
