my sled is all stock and looking to run 53/43 helix with the green sec spring..but my question is what brand should i buy? i hear pioneer sells a good one but they say bender has a more aggressive cut..what should i go with? with the more aggressive bender or the pioneer one?
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
We sell Micro-Belmont for $120.00 plus shipping. If you need the spring, I have them for $18.00
I used a pioneer performance helix quality looks good price was reasonable and shipping was fast
FJViper
80pantera said:I used a pioneer performance helix quality looks good price was reasonable and shipping was fast![]()
X2^^^^^Got the helix and spring. CB will treat you right also.
i forgot to mention, i have a slp can on my viper..will this affect this setup because they say to run this wiith everything else stock? or does that just mean run everything stock in the clutch..
FJViper
Correct, everything else stock in the clutch.
Vipers should run at max 8400-8500 rpm's. Once you install the helix and green spring, 'if' you have rev's higher than that(some Vipers may run around 9,000) you can put some more weight in the tips of your primary. The can shouldn't make a difference. Do a search for 53/43 helix. Should be plenty of reading so you understand everything.
