what brand of helix to go with?
viper700t
NB
my sled is all stock and looking to run 53/43 helix with the green sec spring..but my question is what brand should i buy? i hear pioneer sells a good one but they say bender has a more aggressive cut..what should i go with? with the more aggressive bender or the pioneer one?
80pantera said:
I used a pioneer performance helix quality looks good price was reasonable and shipping was fast ;)!
X2^^^^^Got the helix and spring. CB will treat you right also.
i forgot to mention, i have a slp can on my viper..will this affect this setup because they say to run this wiith everything else stock? or does that just mean run everything stock in the clutch..
Correct, everything else stock in the clutch.
Vipers should run at max 8400-8500 rpm's. Once you install the helix and green spring, 'if' you have rev's higher than that(some Vipers may run around 9,000) you can put some more weight in the tips of your primary. The can shouldn't make a difference. Do a search for 53/43 helix. Should be plenty of reading so you understand everything.
