How to change viper windshield???
srx600
Madawaska, Maine
Hey guys,
First time viper owner and need to change the windshield to a blue one. I've changed srx and rx1 shields before with no problems but I'm lost with the viper. What do I need to remove to get to where it is fastened? I can't access it from the bottom or top easily like the Srx and rx1. Just don't want to break anything either. Please help.
Should be a screw on the inside bottom of the windsheild towards the outside on each side. Then slide it out. Hope that wasn't too confusing...
Windshield
I saw the screws but didn't think it was that easy so I figured I'd check it out with you guys first. Ill do it after work and let you know how it goes.
First - roll the sled down a hill, the windy comes right off. :rofl:
Seriously the 2 screws at the lower rear of the windshield go through holes in it, so they need to come out. The rest just pops off. It helps to pull the "Y" shaped piece above the headlight which just snaps off from the top first.
Windshield
I removed the 2 screws and pulled the windshield away from the plastic pieces that the screws go into. There were some kind of plastic fasteners on the pieces that the screws go in. I popped those off but lost one in the abyss. The windshield pulled right out. Didn't need to take the headlight mask off. Slid the new one in minus the fasteners and its fine.
