780srxgeorge
I liked the 16-35 gearing & w/ a 60* rape on the sceconddariy & a good track it will be a real FUN sled.but your onley going to hit low 90s mph w/ it.but Fun!!.can't wait to see it done.
Two thoughts for you. The front bumpers are notoriusly weak and rust. It's not uncommon for them to be broke without having a front hit (or a very light hit) Next, a cheap fix to your belly pan might be a skid plate. My 96 Vmax MM600 had a crack in the belly pan and I just covered with a skid plate ($20 from a junk yard, as I recall.)
Lucky7 said:I use the Bender direct oil injection kit on both my Exciter, and SRX. works great, the oil supply is in synch w/throttle position. Also, it provides a truer jetting spec. Gas is the only thing that should run though your carbs. When the gas dries up, what do you think ios left in the bowls?
I was actually thinking of doing something like that to stiffen them up a bit. I'm on a super tight budget so this year my primary goal is just getting it on the snow.Lucky7 said:Looks like a Vmax 600 I stripped yesteday, it had a No Fishing from Beach sign for a belly pan! Those plastic cooling hose elbows are familiar too. Guys who did these sleds must be related, they shop home improvement for sled parts.
I think SRX blue would look great on that sled. There's another member on here that painted his that way.
While the skid is out instead of rebuilding it, get a later Vmax, or SCIII. I've got the front strut cross beam off a Vmax to weld in if you change your mind. Very cheap.
PS. I like Dial-A-Jets too. Not everyone does... But you're going mountain riding.
While you've got it apart, if you have welding capabilities, grind down the frame in the front cradle areas. Instead of having just the factory spot welds, completly run the entire seams. I've riden sleds done this way, and it really feels more solid.
Another old trick is to buy a couple of pieces of chromemoly, or steel tube. While the rear bumper is off, pound them in up to the front foot wells. Drill a small hole through , and rivet them in place.
Wish I could remember more, but it's been a long time since I did one of these.![]()
Good Luck, John
i must admit i don't agree with you. all 2 stroke dirt bikes run premix gaz from the factory and actually it's the gazoline itself that make a crusty pasta in your carb when it dries... so why don't get rid of the oil injection ? (only my opinion here lol) i never seen the bender kit you are talking about, it looks interresting too
