mopar1rules
killerklown said:So it looks like I need to up my mains, up the pilots, and adjust stock needle, that right?
you will for sure from stock jetting/stock pipes to the slp pipes.
killerklown
Right, I'm saying I can get the needle adjusted its not a differant needle all together right?
killerklown said:Right, I'm saying I can get the needle adjusted its not a differant needle all together right?
thats correct. if you want the best bet when you put pipes on a viper these days with the lousy fuel and the mono stock head, i would just simply install a carb rack off a 2000-02 srx as it has richer needles and nozzles in them stock. i would however still bump the needle up slightly. its the mid rabge cruising that bites ya in the butt all the time on a viper, lots of timing to build lots of heat.
super1c
Super Moderator
Right same needle different position. I think i ran my cprs in 4ht grove, one shim on top one on bottom. I would have to check my notes for sure but you get the point
killerklown
OK, thanks guys I wanna order my jets tomorrow so I wanted to be sure.
killerklown
should I look into a SRX CDI? Is it plug-n-play? All years same?
Or safe enought with rear cooler, opticool gasket and rejetting?
staggs65
I dont think you'd want a srx cdi running at 9k. the srx timing starts to drop off by then.
bigmuscleclub
hey guys looking for some info.
does anyone know the proper torque setting on and 02 viper for the opticool head?
i bought one which now has 23 miles on the new gasket and wanted to double check the setting before first ride?
cheers
cant seem to find anywhere??
cheers
