Does it matter if my new v belt is about .125 inches below the top
Of ridge on secondary ? Shop manual states no more then .02. Im hesitant on taking apart to add shim as I dont quite understand how this raises the belt. And by adding one washer will it raise it too much ? Sled ran fine with old belt on current adjustment, does it affect performance that much ? Or am I ok. Thanks very much
A couple of bucks
That would be the probably the equivalant to starting out in second gear in your truck.Vtnaples said:Does it matter if my new v belt is about .125 inches below the top of ridge on secondary ? does it affect performance that much ?
