MM70001
Putting Bender pipes on my 2001 MM 700, is the airbox mod worth it or will it cause finicky jetting ?Should I leave it stock ?Any idea of jetting specs with the airbox mod at 2000 ft at -15 c? versus stock box?
It will be WAAAAAAY to finicky. And yes, leave the box stock. You can block off the 4 warm air ports that are incorporated into the hood so only cold air is sucked into the slush box. Start w/ blocking off two, ride then read plugs and adjust from there. This procedure will obviously lean it out . I used 2 inch wide chafe tape on both sides of the cowl so the tape is stuck to each other.MM70001 said:will it cause finicky jetting ?Should I leave it stock ?
