Will the ultra 2 skid plate fit on my 01' srx? Holeshot list the same part number for their skid plates for sxr's and srx's, so I would think the ultra 2 would fit too, right?
daytripper
- Nov 4, 2003
get the mountain max one from holeshot, it goes all the way back and covers the heat exchanger protector brackets.
ejcamaro I found SRX skid plates in my 2005 YAM acc. catalog they look to be a little different than standard pro-action plates. Colors are black or silver. They are an ultra 2 that cover from bottom edge of front lower vents all the way back to the exchanger. Some of this SRX stuff is getting hard to find buy it now. Put the silver one on my 2002, looks very good. 100.00 if I remember right.
Keep In Mind The Ultra Skid Has The Protector That Hangs Down Over The Radias Rods A Bit, They Really Scoop Snow Infrobnt Of You And In Your Face, I Would Not Recomend One
As long as I can get a skid plate that covers up to the the bottom edge of the exchanger I'll be fine.
TopGunnSrx
TJ500
what protector then is recommended? As posted in TECH section, my protector keeps falling off due to ice build-up... (02MM 700)
tj..
tj..
