Viper Backfires...
yamahammer viper
Wisconsin
My viper ran fine about a month ago but now when i start it, it backfires really loud and kills when it does.. never did anything to it... but i need help on it. :o| :dunno:
Key words "never did anything to it" I would suspect your carbs need to be cleaned. Search "backfire" many threads will pop up about dirty carbs. Either way they should be cleaned and go from there.
Yaaamaaahaaa3 said:
While your at it you might as well clean the power valves. If the carbs are dirty, I would bet the valves are too.
i just cleaned the valves maybe a month ago, but its justt weird how a few weeks ago it ran great now i cant even give it any gas and when and if iit gets some RPMs going only two pistons are fireing i took the plugs out and cleaned them, that didnt do anything. still think its the carbs??? :o| #$%&*
Yup, definitely sounds like the carbs. My guess is the pilots are plugs. If you cleaned the valves a month ago, don't worry about them. Just clean the carbs.
