musselman
Really gives a mean look to it though
sleddineinar
alswagg said:How did you do that? The OEM bearings are 12MM wide and the larger wheel bearings are 15MM wide. The snap ring groove is set for 15MM. Did you add some 8" wheels to the inners? That was the spacers which really needed to be modified. Basically all spacers needed to be cut and squared up. The modification was really simple actually.
I'm using a doo 8" inner wheel. I had to buy different bearings to match the shaft on my polaris skid. I'll have to look at what I did now, you've got me doubting what I did, I don't remember... the circlip groove seemed to be right and I didn't have to modify any of the spacers. Hmm...
