I have a 700 VMax with reed stops notched; stock can bored; middle gasket removed from head gasket and stock single pipe. The carbs are stock setup with the exception of fuel screws which are out 1-3/4. I checked the plugs after riding 5 miles in 30 degree weather and all 3 were very light tan and dry. The threads were a little black and slightly wet. Is this too lean or will it be too lean when its 10 degrees out?
