Viper Chaincase Seals
SeX Viper
Minneapolis, MN
Does anyone know why the viper has different part numbers for the top and bottom oil seals on the chaincase? The bore and shaft measure the same so I do not see why they do not use the same one. I looked on the Yamaha web site and the SRX has the same chaincase and uses the same seal on both shafts.
I'm not sure either. Other then they are 2 different colors (one brown/ one black) I couldn't see any difference, maybe the rubber composition is different on the bottom one because it's more exposed to the elements? ?
hmm good question. i will check the seal numbers against each other, never noticed it before.hmmmmm
