94 vmax 500 suspension
db6329842
my house
I have a 94 vmax 500 , I have an issue where the rear of the suspension drops down on the middle idler wheel and rubs. I have removed the suspension and taken out the rear shock. I cannot compress it any amount even with the spring loosened off to the top. Is it possible for the shock to be stuck and cannot compress?When the suspension is out and the shock is in , I pushed down on the suspension and it doe not compress , it wants to roll forward but not compress as it should.
I had a locked up rear/top shock on the XT (different skid but similar principle) and the bumper would only go down about 2 inches that was very rough trip to say the least.
Not sure what you mean when you say it drops down on the middle idlers?
