Mad Maxx
- Feb 18, 2005
if those are viper front shocks on your vmax, make sure you have clearance for the can on the shock when it is bottomed out.
Mad Maxx
- Feb 18, 2005
Those are indeed Viper S shocks.Been running those for a couple of seasons now .Work fantastic. I leave the plastic adjuster knob off the top to avoid clearance issues .Thanks for the heads up.
Love the graphics, Is that paint or decals??
Very cool!!
Mad Maxx
- Feb 18, 2005
The top of the hood and the white is paint. The red stripes are vinyl. My interpretation of a 30 th anniversary sled they never made(but should have). I still have the original hood as well. Glad you like it,thanks.
chris700readhead
Looks very nice
musselman
That looks great
should ride pretty good too.
should ride pretty good too.jasburrito
Those sleds look trick. nice work. I pondered putting a new skid under my sled but decided to have all my shock rebuilt instead. cheers
01 SRX
Nice ride! Northern Michigan has lots of snow now!
There is too many pivot points in a proaction rear skid and its all plastic bushings even after replacing all plastic bushings with new ones they t still really loose and the shock has to flex all those joints before it can react with the sled. If u replaced all bushings with bronze bushings and hard shafts the skid would work sooo much better but would b twice as heavy and it is already heavier than others. All that flexing ends up in the w arm if u ride it hard through the moguls like I like too and that will need repair work soon. I've trashed 3 different ones and ill admit I used to be hard one some of them. Something about riding double with chicks on the back and hammering down. Oh we'll they never left me stranded just couldn't get rid of that feeling of the skid just packing up and not knowing what to do. It's part of the reason I switched to doo for 5 years. I pounded both doos we had harder than my yammy due to the confidence u get after u don't break your sled every time u jump a snow bank and land wrong. But the motor problems they experience aren't confidence builders. So I'm building best of both worlds
the breakage and bushing issues can be overcome. though, hard to beat the ride of a modified mono or a m10
03viperguy
I love my monoBETHEVIPER said:the breakage and bushing issues can be overcome. though, hard to beat the ride of a modified mono or a m10
how do you modify them?rickc
seat
looks awesome man am thinking on do the same thing to mine what suspension did you use and where did you get that seat I would like to get a little higher also any information would be appreciated. thanks RickMad Maxx said:Just got the new M 10 SS under the sled. Can't wait to give it a try....just need SNOW!!!
rickc
will the m10 fit my 99 vamx 600 with a 121 in track if so what is the best you can do cash money I am just across the border from Fort Fairfield. thanks Rick
Mad Maxx
- Feb 18, 2005
Hi Rick. The M10 sill fit in your sled. You just have to follow mounting instructions. There are great details in the tech section. I ordered the M10 direct from FAST. Check with them for their current pricing & shipping. It does take about 8 hours to complete. Seat is from Boss and I ordered it direct from them as well.You'll also need to use a bar riser and I would strongly suggest you have the steering post reinforced. You will snap it off if you don't...its only a matter of time. Check the classified section for used deals.Best of luck on your build.
Mad Really sharp, nice workman that will be one nice ride!
