yankeeslover
going to walmart tonight to buy my antifreeze tester..... gonna change out chaincase oil in morning also as I have no idea when it was done last.. what exactly kind of oil do I look for at walmart or auto store? do I have to stick with yammy brand from dealer? what are others on this site using? don't want to get the wrong stuff... would like to buy it from walmart while im there if its possible but not sure what to look for..thanks
You should use chain case lube. We use Klotz. cost is under $10 per bottle on bottle is enough for two sleds. I don't shop at Walmart so I don't know what type of lubricants they have. Sorry. Anyway, you can buy Klotz chain case lube on Ebay and have it shipped directly to you. Good luck Al
I have used Synthetic Blend Mobile Super ATF for years ,works for my sleds..
Devilin AblueDress!
yankeeslover
I went to autostore.. purchased mobile 1... says syntetic gear lubricant 75w-90 LS.... is this ok? 1 quart was $9.99
yami1
Yes that will work just fine.
ottawaair
yankeeslover said:I went to autostore.. purchased mobile 1... says syntetic gear lubricant 75w-90 LS.... is this ok? 1 quart was $9.99
thats what i have been using for the last 4 seasons
sleddineinar
I use Amsoil chaincase oil. I get it at the NAPA store near me. But I know people who use nothing but straight 30 weight motor oil, and never have a problem.
that is what i have always used for oil weight. using royal purple atm.
I use automatic transmission fluid!
I use redline superlight weight 90w
TopGunnSrx
ATF in mine aswell....
orchie18
I like ATF, its a pretty colour too..jk
Devilin AblueDress!
ATF makes it easy to spt and identify if you spring a leak.......Cuz of the pretty color!
orchie18
That's very true. Mix it with coolant and we have Christmas colours...Fa lalalala
yankeeslover
Actually i did mix it w coolant. Wasn't looking when i was refiling my chaincase and relized i had bottle of coolant. Poured probably tablespoon or so in chaincase(oops).. drained it again, refilled w chaincase oil and drained again to make sure no coolant in there. I guess we know it wont overheat...
super1c
Super Moderator
yankeeslover said:Actually i did mix it w coolant. Wasn't looking when i was refiling my chaincase and relized i had bottle of coolant. Poured probably tablespoon or so in chaincase(oops).. drained it again, refilled w chaincase oil and drained again to make sure no coolant in there. I guess we know it wont overheat...
I got a chuckle out of that. LOL! Its way cool your diving into this and sticking to it. Keep up the good work, and trust me ive done worse by far!!! Thats how we learn!
oil
KLOTZ it keeps your chain and bearings in great shape, chaincase runs cooler and really sticks to gears great stuff
been doing this for years..good stuff..ronclark said:ATF in place of gear oil?![]()
