97 vmax 700 gearing suggestions?
devinzz1
Newfoundland
Im looking for more power off the bottom and was wondering what the stock top sprocket was and If I could drop 1 or 2 teeth without changing anything else (clutch).
sure, drop 1 tooth will make it take off more aggressive, when you change the gear ratio the clutching will change slightly due to a differance in the loading of the engine, it might slightly over rev with 1 tooth smaller, depends on how dialed in your clutching is...
I was thinking that my 1.35 track would counteract this over rev anyways. Do you know how many teeth there are stock?
What would 22/39 do?
not much of anything noticeable really. just to update on this thread after experimenting with 9t drivers 23/40 and 21/40 as well as 8t drivers 23/40 and 21/40. My current setup and favourite is the 8t drivers and stock 23/40 gearing
i dropped a tooth up top when i stretched mine and it helped off the line but it did rev up to 9000 full throttle. No idea how it affected top speed since i never can find a nice straight away.
