Hi guys, this might be my first post here but i've been reading these threads for some time and couldnt find what i was looking for with the search tool. A week or so ago i took apart my carbs and soaked them in some carb cleaner solution and put them back together, replaced my gaskets and reed gaskets and put it back together. I noticed when i started the sled that it wasnt running quite right, so i pulled the coils one at a time to see which cylinders were good and bad. it turns out that the cylinder closest to the clutch was getting spark and fuel but not running well. the machine wouldnt idle on it but if i gave it gas it would run. so i checked the compression on each cylinder and the one closest to the clutch was about 10-15 psi less and lost compression faster than the others. i realize its most likely time to do a top end rebuild, but my question is if i run it this season, will it do enough damage that ill have to send it out to get re-honed? do you guys think im good for this season or should i just invest in a wiseco rebuild kit and do it before i get out? Thanks!
