PhazerII1990
Hello fellow yamaha enthusiasts. I have a 84 440. The stock secondary was foobar so i put a phazer secondary on it. Haven't ridden it yet since old man winter is still on vacation. Am i asking for trouble with this? Input would be very helpful before i break stuff. Thanks!!
Yamaha Nutz
should work just fine might have to do some tweeking with the helix to work right they aare pretty much the same except helix angles ............stock ss should run 6800 -7000 rpms on the top
PhazerII1990
Thats what I thought. I have to gas the hell out of it to get it to move. like around 4500-5000. Worn helix maybe?
Your going to need change the spring wrap. My father did this in the late 80's with great success according to himself. A spring wrap change was necessary but he cant remember what locations to put it in. You could try B-2 which is where the secondary in my XLV is. Different motors but otherwise everything else is the same. You probably have to play with it a bit.
PhazerII1990
Thanks for the input fellas!
PhazerII1990
Another question. What size is the fuel line on this damn thing?!!! Thanks :-)
northerngn
I have 1/4 in on mine...
i have a secondary clutch for an 84 ss440 pm me if you need it. i have all the specs as well if you want to take yours apart and compare it to the stock ss clutch
PhazerII1990
Thanks dschutt but I already have another one for it. just waiting for the snow to fall so i can use the damn thing!!!!!
