well I used pads from them on both my sleds,,they work well.Carry on!!
gil7247
Glad you got it together okay. That can happen, that's why I always recommend using an old pad to press the pistons back in. It makes a flat surface to keep both pistons goning straight and at the same time. You have to watch the aftermarket stuff, I've learned that on several occassions. The good news is now you know something new and Brake pads last for quite a while so you won't have to do that again forr some time.
yep!! it is like anything else..first time takes longer with a lot of questions and aggravation. Second time round it gets easier...you have to make it thru the first round...
Cooper0809
Yes its good experience for sure, but also can be a bit of a headache at times. I was wondering how the heck I was going to get fluid back in the system but I managed to figure it out. The old fluid has probably never been changed and was looking a little brown anyways, so im kinda glad things went the way they did.
