staggs65
you have it bypassed correct then. Now I dont know if the throttle switch is bad if it can kick on the tors while the carb switch is bypassed. anyone know?
viper44
My dad has a blown viper, ya think I should borry his throttle?
Devilin AblueDress!
I am unsure of this as well? Makes sense that it would though as bypassing carb switch is just that.staggs65 said:you have it bypassed correct then. Now I dont know if the throttle switch is bad if it can kick on the tors while the carb switch is bypassed. anyone know?
Viper44, Does the throttle rocker/pivot "float" so to speak? I know one of the ways of testing tors is to hold that from sliding towards the center of the sled and try to give it gas.
viper44
Devilin ablueDress, Yes it floats. Should I try another throttle? I can get my hands on one today. I leave in half hr I will be away from home till this evening. thanks boys!
Devilin AblueDress!
Cant see where it would hurt to swap out and see what happens. Might be worth getting both sleds in same spot to swap parts around troubleshooting.
viper44
Thanks, All try and get throttle today. Getting Other sled dont have a motor in it, Kaboom.
