OK, here are the results; (done by 2 who have no or little experience with measuring these things)
Measured at about -5c, warmed up a little with a hair dryer:
Resistor for handwarmer: From low setting (1) like 10-20 to like 565 at the highest
Resistor for thumbwarmer: Pretty much like the handwarmer. From a couple of tenths to like 560-580. The manual says from 400 ohms? to 600. So it seems like this checks out.
Thumb warmer: 41 ohms, which does sound a little on the low side. It works, it has a tad of warmth on it when on maxx setting. On the continueity test, it gave 68..something. Ohms? EDIT: Is it getting too little current? Is it supposed to be 12V? (Excuse me for my useless knowledge in electric terms). I guess the next thing is to check for a chaffed wire?
Handwarmer continuneity test: left: really low/high? reading, 5 ohms? Right handwarmer, no response, so I guess they are broken right?
Have I interpreted the results right?
I need new handwarmers and a new thumbwarmer? What is this switch the manual talks about "replace handwarmers indivitually or both or the switch"? What switch?
