Got the sled out of storage and after a few laps around the field, it quit and now has no spark. I checked all the plug ins around the airbox. This sled has 7000 miles but has been well maintained. Any help is appreciated!
May be the stator. I had to replace mine at around 5000 miles. would start to run bad and back fire. did not make it home one time, hitched a ride to get the trailer then it started when i got back to it just good enought toput it on the trailer. Also the spark plug caps need replaced if they have never been changed. You can use an ohm meter to test for the stator and the plug caps. I do not know the numbers off the top of my head but your dealer should be abel to tell you.
The sled has a couple bad spellls last year, but we were assuming it was bad gas because the sled hadn't been ridden much. Blue devil, there is no spark no matter how long it sits. It probably is the stator, thanks guys.
