averagesleder
O2viper700 said:Thanks for all the input everyone. I havnt had a chance to try anything yet.
To busy with school and work![]()
Did you get to try it yet? Does yours hang going into corners also?
averagesleder said:Did you get to try it yet? Does yours hang going into corners also?
No, I didn't. I did turn my idle down and that seemed to help so far
But I've only done short trips with it like that. It usually hangs more on long trips like day trips. So if it is still hanging to the point that's its anoying I will try the other things.
I will report back after I do a long trip.
that idle hang is basically a norm for the sleds.Mine on the 600 is always there.Tried everything to get it down..no success.I have fuel screws to 2.5 turns out even.If I turn the idle down..it does drop quicker..but eventually idle will drop to low and when you start the sled first time the motor doesn't idle up at warm up unless you block the throttle open with something.If after a long run you adjust your idle to around 1500 and it stays there..then next day start it cold..again idles to low at warm up..just got to find a mid point I guess.
On my SRX same thing.I went to 50 pilots and fuels screws turned right out and still fast idle,so had to turn down idle on purpose..so it idles near normal after all day running..but in the morning first start..again idles to low for warm up..have to feather throttle or wedge it open a little more until warm up. A little of a pain..don't know why this happens on the Yami motors...but it just does.
apparently there was a recall on the throttle postition sensor.
i was reading on a forum and the guy said he replaced his throttle position sensor and the idle hang was fixed.
maybe for the Viper and SRX..what about the other sleds...changed mine on the SRX,hang is more controllableO2viper700 said:apparently there was a recall on the throttle postition sensor.
averagesleder
O2viper700 said:No, I didn't. I did turn my idle down and that seemed to help so far
Thanks I'm going to do the same thing. My fuel screws are now out two turns. I'll put it back together and turn the idle down. I'm going riding on the weekend,i'll see how it is.
averagesleder said:Thanks I'm going to do the same thing. My fuel screws are now out two turns. I'll put it back together and turn the idle down. I'm going riding on the weekend,i'll see how it is.
Where are you going Riding? I didn't think niagra had snow.
averagesleder
O2viper700 said:Where are you going Riding? I didn't think niagara had snow.
We don't, I'm going to North Bay. It sucks not having snow to be able to test.
averagesleder said:We don't, I'm going to North Bay. It sucks not having snow to be able to test.
Ya trails r suppose to be good there. Have fun
yamyrider
trails are excellent in Sudbury
teamblue02SRx
Was having the same problem with my srx turned fuel screws out to 1 3/4 out still hung a little not as bad so I turned the idle down from 1800 to 1500 seems to be working better didn't have it out for a proper test but it wouldn't hang playing in the Feild
