b16racereg6 said:Thank You, any idea ware i can get a bearing? local autoparts store or online some place like dennis kirk? Whats the bearing called so when i call up and ask for it i dont sound like a total idiot lol. Is it the clutch side Drive shaft bearing? Thanks For the Help I will +Rep ya!!!![]()
Yes clutch side driveshaft bearing, Im not sure of Yamaha's part number, but its a 6004-2RS series bearing, I use NTN bearings their part number is 04-152-010R. Dennis Kirk will have it for sure give them the 6004-2RS number.
snowmobile Mike
I was able to get the bearing off without removing the driveshaft now my next question, do I need to press the new bearing on or should it just slip on? I played around with the new bearing and I wasn't able to just slip it on..
sleddineinar
snowmobile Mike said:I was able to get the bearing off without removing the driveshaft now my next question, do I need to press the new bearing on or should it just slip on? I played around with the new bearing and I wasn't able to just slip it on..
Just clean the shaft with some emery cloth and it should just slip on.
sleddineinar
brade07 said:Yes clutch side driveshaft bearing, Im not sure of Yamaha's part number, but its a 6004-2RS series bearing, I use NTN bearings their part number is 04-152-010R. Dennis Kirk will have it for sure give them the 6004-2RS number.
Unless the 95 Vmax 600 is different than my 96 Vmax 600, that bearing is a 62/22 2RS. Dimensions are 22x50x14mm. Do a search on Ebay, I paid 7.99 w/ free shipping and it was British made, not Chinese. The dealer wanted $38 for the same bearing.
b16racereg6
sleddineinar said:Unless the 95 Vmax 600 is different than my 96 Vmax 600, that bearing is a 62/22 2RS. Dimensions are 22x50x14mm. Do a search on Ebay, I paid 7.99 w/ free shipping and it was British made, not Chinese. The dealer wanted $38 for the same bearing.
Oh yeah checking now. From what it looks like Easy enough job basic hand tools maybe a few hrs for a noob like myself. Il try and take pics in the next week and make a diy maybe ok. If i rember to take photos.
A couple of bucks
I found out that our local ACE store, actually stocks them. I found them in the isle w/ all of those pull out boxes. This store has an entire isle(50 ft) w/ those pull outs on both sides of the isle though.
