Yooper Dooper
Anybody have any expierence with Pioneer Performance and this kit? I have a stock 02 that I am thinking about adding a little bit more shock to it. I got a couple of 4 strokes but sure do like to ride my SRX on good trails. Any issues with handling? Is it worth the $$$? They claim it will sit like an SXr and Viper?
Devilin AblueDress!
I have an 00 that came with pioneer kit already in it(front&rear). I like it. Rides better than the GFs SxR or the "viper shock long travel" under the 01 srx.
I have the pioneer shock extenders upfront on my '02 and the rear is a complete viper assembly.( Same thing) The only difference is that pioneer will revalve the viper shocks to work...."better"
My honest opinion....The thing is a lot better through the bumps but I can't help but I am ALWAYS looking to regain that legendary srx handling in the corners. The center of gravity is higher now so in my opinion it just handles like every other sled out there. It is harder to pitch into a corner and the skis lift is doubled.
To each his own.....I still have mine in but I am really thinking of swapping just to test but the lack of snow makes it hard.
if you go up without going wider, you will make the sled need more input or, negative laziness in the corners. I prefer to set a sled up for positive laziness. wider, bigger bars, and as low as you can get it.
Yooper Dooper
Good info guys, I really like to leave it stock and did not want to alter the handling of the sled at all if possible. thanks
Yooper Dooper
Hey Devilinabluedress, Im in Indian River and sled your way, maybe we'll catch you on the trail and swap SRX stories...
BETHEVIPER said:if you go up without going wider, you will make the sled need more input or, negative laziness in the corners. I prefer to set a sled up for positive laziness. wider, bigger bars, and as low as you can get it.
X2 - I too am lazy.
Go wide and you won't regret it.
Devilin AblueDress!
Yooper Dooper said:Hey Devilinabluedress, Im in Indian River and sled your way, maybe we'll catch you on the trail and swap SRX stories...
I was in indian river a couple times today.....WORKING! Damn 2011 ford pick up and no where nears as fun as the SRX! Hoping weather holds out ot comes back as snow is getting hammered!
