A little background first....
I bought this project sled for my wife for cheap last year. It had a center piston melt down and I rebuilt the entire engine. Had the crank rebuilt and all new gaskets and pistons, etc.
Got it running last season and it ran fine through an entire rank of gas. Took it out this season and ran through a half tank of gas. It ran rough at idle so I figured the carbs needed cleaning. Sure enugh when I took them off the pilots were clogged. Put everything back together and it purred like a kitten.
After the carb cleaning I didn't really bleed the cooling system, which i think may be the issue, but is what I am looking for some expert opinion on...
Anyway, took the sled out last weekend and while riding fairly easy, the sled comes to a stop and shuts off. Seized. Get it home and take it apart and the mag side piston is melted down. The other two look fine.
So, I am hoping it is due to not bleeding the coolant and having no circulation in the coling system. Do you think this is likely the cause, or should I be looking for some other reason for the meltdown? I have a new piston and jug on order but I don't want this to happen again.
The sled ran great after the rebuild and this season until I took the carbs off and didn't bleed the coolant system.
Let me know what you think and point me in the right direction!
Thanks!
Thanks!
