nelsonhouse
the helix is 51-43 with green spring and i don't know what brand the helix is. i will check it out tonight. i'll take a pic of the helix and post it. What angle helix would you recommend?
yamalars
38-40 finish angle, i would go for a 51/38 sins you can always add some weight if she
overrevs, right? And stay with the same brand helix u got now. (diff. brand= diff. cut )
Also i would try a run with mid empty @60 wrap as a band aid just to how she reacts.
If you dont mind me asking what u end up with loading your weights with in the end after the new spring? U are running 15.6mm rollers to right?
nelsonhouse
i do not know what size rollers are in the clutch. how do i measure the size of the rollers?
Calipers if not there can be defined by the lines on them on outside. I beleave so anyway.
nelsonhouse
yamalars
??? But post it here and someone will likely nail it!
http://www.totallyamaha.net/forums/showthread.php?t=61494
its a Dalton helix
