Yamaha SX 700 Crank Bearings Problems
SRXLance
Erie
Last year my flywheel side crank bearing seized with around 4000 miles on it. Tore the motor down last year and replaced all the outside crank bearings. Put the sled back together and ran good. 100 miles later the same thing has occurred. Any ideas.
How do you make sure the holes in the case and the bearings were lined up. The bearings have pins in them, so shouldn't they be correct?
I just re-assembled my 700sx, the crank bearings have small roll pins (anti rotation) that sit in little pockets that are cast into the case half, there arnt any oil holes in the bearing. The bearing is lubed by little grooves in the top of the case half that have holes up thru the top half of the case to the bottom of the cylinder. As the piston comes thru bottom dead center the fuel air and oil mixture is compressed in the base and some of it passes thru the bearing and up thru the oiling groove to the top end, this allows a small amount of oil to stay in the bearing. Not sure why you are having problems? Perhaps the crank is out of true causing stress/vibration in the bearing? Is the oil pump bled, adjusted and working properly?
