Yamaha_Ryder
It's been a while since i've put a viper chaincase back together... Waiting to get extrovert drivers pressed on, can I install the chaincase before I get the driveshaft back? Thanks.
thefindian
No you cant put it together in that order. Driveshaft goes in first.
X2 what he said.I tried that the first time I changed a track and found out the hard way after I had everything all loctited back together.
ottawaair
Yes, actually you can install the case. But, you will have to have the bearing removed. Then install the bearing on the shaft once it's in.
