Silly question... Can I install chaincase before the driveshaft?
Yamaha_Ryder
Edmonds, Washington
It's been a while since i've put a viper chaincase back together... Waiting to get extrovert drivers pressed on, can I install the chaincase before I get the driveshaft back? Thanks.
Yes, actually you can install the case. But, you will have to have the bearing removed. Then install the bearing on the shaft once it's in.
