Shafner79
So i see that I have a broken primary spring....
I can only make out 2 yellow marks on it. Any ideas what it is? Possibly a Bender orange primary spring? I have a hauck magnum power shift, with a red spring. V-Force Reeds, Cold Air Kit, Studded, Bender Silencer.
Anyone think the damage around the broken spring is cause for concern? I've learned a lot working on my SRX, but know jack about clutching. Do I just remove the 6 small bolts on the primary cover to replace the spring?
Thanks for the help.
YAMMIEGOD3:16
EASY FIX MAN, GET THAT OUT OF THERE. JUST PULL YOUR COVER. (6 bolts ) AND YOUR CLUTCH BOLT. THATS A HAUCK ORANGE SPRING. 3:16 (yammie tony)
Shafner79
Thanks man! I'll get at it tomorrow.
Shafner79
YAMMIEGOD3:16 said:EASY FIX MAN, GET THAT OUT OF THERE. JUST PULL YOUR COVER. (6 bolts ) AND YOUR CLUTCH BOLT. THATS A HAUCK ORANGE SPRING. 3:16 (yammie tony)
Besides Hauck....anywhere else to find that spring?
YAMMIEGOD3:16
Dude, Just Call Hauck. 3:16 (yammie Tony)
Devilin AblueDress!
http://www.totallyamaha.net/forums/showthread.php?t=88730&highlight=orange
Dont know if bender orange is same as hauck orange or not. Should call and check specs (or check website) and know what else would be similar.
Shafner79
Devilin AblueDress! said:http://www.totallyamaha.net/forums/showthread.php?t=88730&highlight=orange
I called Hauck....Bender Orange and Hauck Orange are different. They're shipping me one on Monday.
