Broken Primary Spring
Shafner79
Etters, PA --- Ride in Potter/LH
So i see that I have a broken primary spring....
I can only make out 2 yellow marks on it. Any ideas what it is? Possibly a Bender orange primary spring? I have a hauck magnum power shift, with a red spring. V-Force Reeds, Cold Air Kit, Studded, Bender Silencer.
Anyone think the damage around the broken spring is cause for concern? I've learned a lot working on my SRX, but know jack about clutching. Do I just remove the 6 small bolts on the primary cover to replace the spring?
Thanks for the help.
EASY FIX MAN, GET THAT OUT OF THERE. JUST PULL YOUR COVER. (6 bolts ) AND YOUR CLUTCH BOLT. THATS A HAUCK ORANGE SPRING. 3:16 (yammie tony)
