Yamahasrx700
Where are you from?
red6sx
- Dec 4, 2005
Yes I have checked the TORS at the switch also and its working as it should and
I have slack in the throttle cable. Checked battery.....it tests over 12 volts! Yes I could unplug the grips etc......just another bit of info, I have also bought another CD box ....no difference......I must be missing something or maybe its the Kimpex stator! I have just purchased a Yamaha Stator but it will be a few days until it arrives. I have also ordered a needle an seat for the PTO carb as that appears to be wet with fuel....although that is the cylinder with the larger main jet (factory)so it will run richer!
Yamahasrx700
Ok. Then I cant stop over after work and help you
possibly the crank seal? check and see if it sucking air by spraying ether behind the clutch. sounds like you covered everything else.
red6sx
- Dec 4, 2005
I don't think its the crank seal as plugs all look fine except the PTO which is rich and a bad crank seal would produce a lean condition not rich!......although previously I did perform that spray test without any results. Thanks to all for the suggestions though....They are all much appreciated!
red6sx
- Dec 4, 2005
I am waiting for my New Yamaha Stator to arrive as I did another resistance test and the New Kimpex Stator failed 2nd source coil test in the manual, using the brown and brown/red wires......starting to wonder if there is some existing condition that is causing the stator to blow???
Kenora
Have you spoken to Tony Pinter yet? He is the local (Southern Manitoba) expert on all things Yamaha...His shop (Pinter Ent) is on Hwy 207 just N of Dugald Rd... PM me if you want his Ph#.... my sled is there for some work and I wouldn't consider taking it elsewhere..
the heck with waiting...check your PM for his #
hey Tony Pinter's name sounds familiar.Think I spoke to him years back on some parts.Good to know he has a shop and does Yamaha stuff.
Have you inspected the choke plungers? maybe that one is stuck . just a thought.
red6sx
- Dec 4, 2005
Yes chokes have all been pulled cleaned and checked!.... and yes I was thinking about giving Tony a call....Does anyone know the whereabouts of Perry Bodnar formally of Arborg Sports and Westshore Marine?
red6sx
- Dec 4, 2005
Well I just installed the new Yamaha Stator and it runs better but not quite right.... it still breaking up at higher RPMs???
Cam/ Viper adict
Hey red, I am from just outside winnipeg and have a 99 Venture that I maintain.. If you need some help I can come take a look and listen and maybe two heads can be better than one... As someone suggested Tony Pinter is a huge Yammi guy and fixes them.. He is on hwy 207 north of Dugald.. I know him well and he is awesome.. PM me if you want some onsite help...
Cam..I heard Tony has a short fuse and can lose his temper easily..
Cam/ Viper adict
bluemonster1 said:Cam..I heard Tony has a short fuse and can lose his temper easily..![]()
I havent encountered that with him.. I know him because I am good freinds with his girlfriends family and get together at functions and things.. I have gotten parts and advice from him with no problems.. He does know his Yamahas very very well and I suppose he could have short temper but he may tolerate me because I know the family well...lol.... I ride with his brother once in awhile and he is cool..
red6sx
- Dec 4, 2005
Hi Cam; Yes Thanks, I have phoned Tony as I am rechecking things for the third time now!!! He has not called back yet but I just phoned him yesterday.
I am now wondering if the battery or voltage regulator can cause such issues??? ......or what are the odds that I have 2 bad CD Boxes?? They are both used.
Cam/ Viper adict
Tony usually rides on weekends and doesnt return calls till the week.. I have run my venture with a completly dead battery(it froze) and I didnt encounter any problems. Do a load test on the battery and check, not sure what a voltage regulator would do but you can check if it is faulty.. It is possible to have 2 bad cdi boxes but sounds like I would check coils, reeds, stator, stuff like that and eliminate the easiest possibilities first.. Like I said if you need a hand pm me and maybe get her purring in no time..
red6sx
- Dec 4, 2005
Just wanted to add that I pulled the throttle paddle assembly off a running Yamaha just to rule out the TORS switch on the throttle paddle.....No Difference!
you say its breaking up at higher rpm,..... does it still reach peak rpm?
SX600abuser
Any TY members by you that can donate a carb rack to try real quick? Then you can completely rule out fuel/air issue.
