95rxl650
I'm putting my sled back together today after doing the bearings. Nothing but the case itself is buttoned up and as I was putting the gears and chain back in place, I noticed the chain sticks out about 1/16 inch past the lip of the case at the top gear while the bottom is inset about 1/4 inch. The chain seems to be aligned looking from the front, but the tension wheel does not come flush with the leading edge of the chain either.
Case is tight to the tunnel, so the top sprocket should be sitting where it needs to be. Ya I know, take pics as you work if in doubt. I just didnt notice as I disassembled it. It is back together the same as it was disassembled.
Normal? Is the case built wider/deeper at the bottom?
