1320ft setup stock 2002
t-rav
hanmer,ontario
k guys im looking for a good setup for 1320ft im goin to try running the north bay runs on feb 9-10 i currently have hauck 51/43 with silver spring wraped at 60 and in my primary i have 8bu-10 with 4.5 at tip with a brass washer not sure weight and i thing 3 grams in middle with a maxxx white with 2 engagement shims gearing is stock at 23/38 machine is stock
u should run a green spring secondary ...what current rpm are u running ?? how mutch total weight u got ....what is the white maxx specs ??
t-rav said:
i got a 52/40 50/45 54/42 58/42 60/40
i would try 50/45 or 54/42....for radar runs you want more acceleartion at a higher speed than a lower speed because you will be on the track longer and therefore have more time to build speed, so ideally you want a steeper finish angle if you have enough hp to pull it
its hard to talk about helix ...no brand helix work the same with the same degree....if its close to Dalton helix he is pretty bang on ,,,,,
52-40 IS THE BEST CAM FOR YOUR SET-UP OFF YOUR LIST. GO TO THE GREEN SPRING AT 80 WRAP. 8BU-10 PULL LIKE A FREIGHT TRAIN. YOU ALSO DON,T NEED 2 ENGAGEMENT SHIMS. USE ONE WITH THAT MAX WHITE. THIS IS SPEED RUNS, NOT DRAGS. 3:16 (yammie tony)
We have run that distance and done very well with a set up very close to yours right now. The only big difference in our set up is we run a softer secondary spring at a very low wrap. Trick is to not suck the belt down on launch and hold rpm's. Your going to have to be very fast in the bay! This weekend the stock 700 trail class ran 111 on sat. And 114.9 on sun.
Those are very fast speeds in 1320 on trail studs!
We ran the red! Started at 60 dregs and worked our way softer as we tested.
F7's ran those #s
Two former SRX guys.
2fastsrx from this form and my son.
Not sure how a well set up SRX would have run. I didn't have one to bring and the ones I did see there where obviously not set up!
Best SRX stocker I saw was under 110 mph.
We ran a 123.6 with our 600 improver with a lot of hard work. We only managed 1 full pass all weekend. Puked o rings in the head 3 times. Found a warped head to be the cause so we tried lapping it. What a chore that was! We did get it to hold for a pss though.
Our competition ran a 126.1 so we didn't even get very close. Maybe in the Bay we can give him a bit more competition!
im running 3 gram in both hole with a w-w-w with a ported engine running 8700 ..thats beast fly ;)!
could run a b-w-b on bare ice for radar
thats why i sold the srx guys was always getting beat by f7's in 500ft drags and 660 and 1/4 mile speed runs .cant beat um join um lol i will admit i do miss my 02 srx .i tried every thing i could to beat them .there just to light the f7's .look on nssr website f7,f7,f7 lol it ant just here in canada lol well set up f7 will have a slight advantage over a well set up srx maybe not in 2000ft plus
never had a problem with any f7 this year from out of the hole across the lake best speed i seen one do was 115 in 2000+ft
We do have separate classes for the single and multi pipe race stock 700 classes. The 2003 F7 is definitely fast. We ran 112.2 last weekend with our SRX 700 in 1000 feet. Not close to the record yet but we are working on it.
see you in the the bay :) looking forward to seeing my old sled t-rav
:winterrul
