hessracing
Hey guys Ive posted on here a few times now about this sled I pulled the carbs and cleaned them all 3 pilot jets were plugged shut and the main jet in the center carb was just floating in the bowl! put it all back togather and seemed to be running fine now its loading up on bottom end and fouling plugs do i need to take them back off and clean the pilot jets again think there plugged? I ran it hard and it will pull through strong once its going but doesnt not like slower ridding seems to build up
taylzee
If it's loading up, the pilots aren't plugged. What are the fuel screws and needles at?
hessracing
I didnt touch them I'm going to have to pull the carbs off and set them what are the best settings just go stock or is there a setting that works better?
SX600abuser
Check your air jets!! Double check your fuel screws too and make sure they are all turned out to the stock setting.
hessracing
stock is supposed to be 1.5 turns out I'm going to tear them off and re set them again i also think that i had the choke cable a bit tight so it might of been opened up a bit i backed it off and seems to be better recomended idle is 1600 but seems to run better with a higher idle does that seem to be an issue with anyones?
