got-wood
Here's a question that perhaps someone could answer for me. I had the thought of using a viper gauge on my vintage project and was trying to figure out how to make it work. The speedo is easy and I have most of those parts already. What I don't know is how to make the tach work? Surely that can be done. This will be used on a 433 Exciter. Anybody? Thanks
			don't think  the tach will work on it ...the pulse signal are not the same ...you could use a 98-99 srx tach ...if im not wrong
			got-wood
Well, I'm not an electronics guy, that's why I'm asking the question. To me, its just an electronic signal. Maybe changing something in the gauge? Maybe I'll talk with a gauge place, but I still need more details about this Viper gauge before I could do that. There has to be a way.
			viper got 3d ignition system ..old sled don't ...
			got-wood
3d? Forgive me, I don't know what that means.
			musselman
The viper will give 1 pulse per revolution to the tach where as the older twins will give 2 pulses and the triples will give 3 per rev. So your tach reading will not be correct unless I'm wrong about how the exciter works.
			got-wood
I wonder if the tach module in the gauge could be swapped out for something compatible? Do they even come apart?
			got-wood
Oh, I get it now. Did a little research last night, 3 pulses per revolution vs 2. May have to look at changing the tach module out and replacing with 'gulp' a Cat unit! Definitely don't want the whole CAT gauge on my YAMAHA! There is also some very good gauge manufacturers out there that have products that would work that I have already found as well. I guess I'm going to have to get one and pick it apart.
