Stock clutch specs for a '95 Vmax 600
Exciter570
Sacramento/Buffalo
Does anyone know the stock rivets used in the clutch weights for a '95 Vmax 600? I just had the primary rebuilt, but the engagement is too high and the rpms in the mid range are way too high..not good for trail riding...
When the primary was rebuilt the dealer put rivets in the weights according to GYT specs since I have GYT twins on the sled..but I'm not happy at all with this set up..it ran much better on the trails with the previous set up...
So I'm thinking maybe there's not enough weight in the tip causing the engagement and mid range rpms to be higher than I want..
CHRIS, MAD AT YOU. SHOULD OF JUST ASKED ME lol. HOW ARE YA. SURE I HAVE THAT INFO.
WEIGHTS ARE - 8CA-17605-01
INNER- OUTER - 4.5 - 90261-06033-00
PRIMARY SPRING- G-P-G - 90501-581L6-00
3:16 (yammie tony)
Thanks for the info, Tony!! I'm doing well, haven't ridden in a couple years but this year had a promising start so I decided to get the 600 ready.. now just need to get the rpms down for trail riding..
How've you been? Still racing the '95??
