Exciter570
Does anyone know the stock rivets used in the clutch weights for a '95 Vmax 600? I just had the primary rebuilt, but the engagement is too high and the rpms in the mid range are way too high..not good for trail riding...
When the primary was rebuilt the dealer put rivets in the weights according to GYT specs since I have GYT twins on the sled..but I'm not happy at all with this set up..it ran much better on the trails with the previous set up...
So I'm thinking maybe there's not enough weight in the tip causing the engagement and mid range rpms to be higher than I want..
